Home | Forums Home | Forums Main | Links | Calendar | Downloads | Help | Chat | Gallery
Scream And Fly T-Shirts
Freeze Frame Video
Brucato Machine and Tool - www.brucatosvs.com
Aerospace Lubricants
Go Back   Scream And Fly Powerboat and High Performance Powerboating Discussion Forums > Main > Props, Setup, and Rigging
Notices
Props, Setup, and Rigging How did you set up your boat? Engine height, setback, prop, etc. Tell everyone what works, and what doesn't.
Reply
Thread Tools Display Modes
  #1
Old 02-02-2009, 04:55 PM
cpeldridge cpeldridge is offline
Junior Member
cpeldridge has a Bronze reputation level
Question 22' Wellcraft Scarab Prop Ideas
Hey Guys,
I recently bought a 22' Scarab with 7.4 454 with a Bravo 1 outdrive. I am having some issues with the prop. I am pretty sure there is a 26 pitch prop on it (couldn't find a number....??). What do you suggest?
Thanks,
Chris Eldridge
  #2
Old 02-02-2009, 05:35 PM
Hottrucks's Avatar
Hottrucks Hottrucks is offline
Team Member
Hottrucks has a Bronze reputation level
that sounds about right..........what is your speed and rpm you could figure it close that way if you run the #'s backwards..........
besides that welcome to the Madness and be sure to fill in your location under user CP
__________________
Quote:
Originally Posted by 1BadAction View Post
I'd slam my d*** in a car door before I'd comment on this thread.
This almost beats cheesey!!!
  #3
Old 02-02-2009, 08:10 PM
Junior Member
Not sure about the speed... I would say 55-60mph... I could turn 6000 rpms if i wanted to though. I was thinking that 4800-5200 is all I should?? I am used to my 1974 Powercat with a 150 Yamaha on the back, so I may have a lot to learn on the whole inboard deal...lol. Anyway, I didn't want to over do it on my first time out on the boat. I think the prop is too high pitched because my hole shot is HORRIBLE...I need to grab more water. It cavitates and i have to really work at it to plane the boat. Let me know what you think. Thanks for the help!
I'll try to fill in my location...
Chris
  #4
Old 02-02-2009, 08:16 PM
BUIZILLA BUIZILLA is offline
Senior Member
BUIZILLA
no wayyyy your turning 6000 rpm with a 26" prop on that hull..
  #5
Old 02-02-2009, 08:19 PM
Junior Member
okokok... A failed attempt say that it seemed as if i could turn it as fast as i wanted.... It was probably more like 5500 really. That is "IF" the gauge is working properly. Remember I just bought the boat and really don't know much about it.
CE
  #6
Old 02-02-2009, 08:22 PM
Sheer Insanity's Avatar
Sheer Insanity Sheer Insanity is offline
Senior Member
Sheer Insanity has a Bronze reputation level
26 bravo would be a good starting point. That motor should only turn 5500 max. It should have a rev. limiter set at 5250
__________________
Welcome to my presents....
  #7
Old 02-02-2009, 08:27 PM
Junior Member
How good of a hole shot would that give me though...? I'm curious if I can race this boat against some outboards.
CE
  #8
Old 02-02-2009, 08:38 PM
Senior Member
Quote:
CE
Nope. Unless your blowin or sprayin don't. 22 foot with a big block in the back will be a pig until it plains out.
__________________
  #9
Old 02-02-2009, 08:44 PM
Junior Member
Kind of what i figured... oh well... i got another boat for those boys.. lol what kind of speed do you think i can get outta this boat...
  #10
Old 02-02-2009, 08:47 PM
Senior Member
BUIZILLA
5500 rpm from a stock 7.4??
uhhhh, nooooooooooooooooooooooooooooooooooooooooooo
  #11
Old 02-02-2009, 08:52 PM
roadtriprhino's Avatar
roadtriprhino roadtriprhino is offline
Platinum Team Member
roadtriprhino has a Bronze reputation level
scarab
I had a 22 scarab with fuel injected 454 back in 96 and it ran 72-73 at best in perfect conditions low fuel no passengers.It did ok out of the hole,but it ain't no drag boat. good luck
  #12
Old 02-02-2009, 09:00 PM
Junior Member
Will do. Thanks for the advise! I may have a few more questions in the future for you if you don't mind.
CE
  #13
Old 02-02-2009, 09:04 PM
Junior Member
I also forgot to mention that it has aluminum heads on it.... Not sure if that makes a HUGE difference or not....???
  #14
Old 02-03-2009, 09:13 AM
markt111 markt111 is offline
Senior Member
markt111
verify your prop, theres a # somewhere.... should be running a 21-23 pitch with that setup at 4800RPM or so in the 60MPH range + or -, with it lugging out of the whole i would def want to verify the tach, if it's lugging maybe you do have a 26 on there turning under 4000RPM, with a sterndrive running deep you want a 3 blade like a Mirage Plus for best overall.....
  #15
Old 02-04-2009, 09:47 AM
RIVERRUMMER 70's Avatar
RIVERRUMMER 70 RIVERRUMMER 70 is offline
Senior Member
RIVERRUMMER 70 has a Bronze reputation level
More Info ?
HARD TO TELL WHAT MIGHT CHANGE WITHOUT MORE INFO.....
ALUMINUM HEADS WITH WHAT HDWR????? VALVES, ROCKERS, CAM, CARB.??STOCK OR HP EXHAUST MANIFOLDS, INTENDED RPM FOR THIS MOTOR COMBO? DID YOU BUILD THE MOTOR OR HAVE IT DONE BY SOMEONE ELSE? IF SO WHAT HP DID THE BUILDER CLAIM WITH THE CHANGES THAT WERE MADE??
ALL OF THESE THINGS WILL BE IMPORTANT AS WILL YOUR ACCURACY IN ANSWERING QUESTIONS ASKED BY THE EXPERIENCED MEMBERS HERE.
IF SOMEONE ASKS WHAT RPM YOU CAN TURN MAX WIDE OPEN YOU NEED TO BE DEAD ON WITH YOUR ANSWER, NOT I THINK OR MAYBE I COULD I MIGHT HAVE IF....... ITS THE ONLY WAY TO GET A GOOD ESTIMATE BASED ON EXPERIENCE.... WITH THAT SAID, WHAT ARE YOUR LATEST RESULTS YOU CAN POST ....
1 PROP. TYPE, MFG, PITCH, PART NUMBER IF POSSIBLE.
2.BOAT. FULL GASS, OR EMPTY, GEAR, EXTRA WEIGHT...DRIVER ONLY
EXTRA WEIGHT WILL CHANGE RESULTS IN TESTING SO TEST THE WAY YOU RUN NORMALLY!!!!
3. MOTOR SPECS,MODEL YEAR, HEAD MFG #, CAM, VALVES, ROCKERS, CARB, JETTING, IGNITION TYPE MFG, EST HP,THIS CAN NOT BE OVERLOOKED AS MANY PROBLEMS CAN STEM FROM AN IMPROPER MOTOR COMBO!!!! JUST BOLTING A SET OF ALUM HEADS ON AN OTHERWISE BASIC STOCK MOTOR WILL DO VERY LITTLE WITHOUT SOME OTHER UPGRADES TO COPLIMENT THE CHANGE....
OR JUST A BAD TUNEUP, BOTTOM LINE BE SURE THE MOTOR IS RUNNING STRONG AND AT MAX "RECOMENDED" RPM ....
WITH ANYWERE NEAR 350-400 HP THAT 22' SCARAB SHOULD RUN 70+ NO PROBLEM!!!
1. MIRAGE PLUS 23"-25"
2. HYDROMOTIVE 3-BLADE 24"-26"
3. HYDROMOTIVE 4-BLADE 23"-25"
THESE ARE SOME GOOD BLADES TO TRY
__________________
Reply
Tags
22', props, scarab
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1997-2009 Scream And Fly, Inc. All rights reserved.
